Is anyone having issues with the forum ATM?
WYP
News Guru
Just a quick spot check to see if anyone is having issues with the OC3D website and forums ATM.
I had some slowdown today, but it appears to have been down to a bad Chrome update. Updating my browser fixed things for me.
I hope that nobody else is running into any issues ATM. Please post either way.
Thanks.
Yeah yesterday I wasn't able to access the forum for a while and was getting an error. 412? 512? can't remember. I figured it was my connection as another forum I visit was also on a go slow.
It's been fine today. had it running really slow yesterday evening, as AA says I had a couple of other sites that weren't great so assumed it was connection issues
I did the other day. Extremely slow loading. Did not update my browser just simply closed the browser and them tried to load I'm a new window and same problem. Waited about 5 mins and tried again no change. Restarted my router and all seemed fixed. Very strange behavior since no other site was giving me issues.
I experienced some issues yesterday on my iPhone, using Firefox.
Just kept on loading, then got two different errors - one was an database error and the other was one of those "You/client is fine, router is fine, webpage server is down".
Once it worked, it was extremely slow and it never truly finished loading in the forum at all.
Each page I went to, looked a bit funky (half bottom was black (like it hadn't loaded in fully/properly and the page was streched sideways, ie I needed to scroll the page to the side to see whole post, which I've never needed previously etc).
I did try other forums as well to see if it could have been my connection, but those worked just fine at the time.
I just experienced some weirdness, got an error from Cloudflare:
Error 520
Ray ID: 5e029ed5dde4302b • 2020-10-10 19:06:46 UTC Web server is returning an unknown error
Error 520
Had a few issues with a few different sites the last couple of days.
Either they didn't load and I got a error, or they took a few minutes to load.
I wonder if tomorrow I am going to see anything about it when I log in to work.
Thank you all for your posts so far. In my case, I have only seen slowdown in Chrome, but none in Edge.
Can folks say what browser they are using if they have seen slowdown?
Been having issues in Firefox as well
