Hi all, I'm having issues since i upgraded to Windows 10
When i boot the pc it posts fine and goes to code AA as normal, the windows spinning circle starts and just before the login screen appears the entire PC shuts down and starts to boot again after a few seconds. It will go through this cycle twice and on the third time the windows repair screen comes up advising it could not repair the pc. Rebooting after this screen Win10 boots fine and works. I have taken a few steps to try and sort out ->
1. Installed all new Win10 drivers from ASUS support site
2. Disabled fastboot in both OS and BIOS
3. Upgraded GPU drivers to latest Win10
4. Ran sfc /scannow (1st time found and fixed corrupt files but all since find no violations)
5. Ran chkdsk -r no issues found
6. Performed clean install with only standard install drivers, same issue
7. Installed all updated drivers on cleqan install, issue remains
I re-imaged Win 8.1 and the issue is not there so i can rule out bad PSU etc
I contacted Microsoft and am still waiting on a response.
I contacted ASUS support who say the issue is with Windows 10 and i should just stay on Win 8.1 until MS patch the OS
My system spec is as follows:
Rampage IV Black Edition(Bios 0801)
Core i7 4960X
16GB HyperX Beast 2400OC
ASUS Matrix R9 280X
Coolermaster V1000
Samsung 840 SSD(OS)
I was just wondering if any other RIVBE owners have had similar issues upgrading to Win10.
Many thanks!!
Core i7 4960X
ASUS Matrix R9 280X
Coolermaster V1000
Samsung 840 SSD(OS)
Many thanks!!
