M mrapoc New member Dec 4, 2012 #1 Already tried it in a standard sata to 3.0 adapter and its detected..just doesn't seem to read anything? Not enough power?
A airdeano New member Dec 4, 2012 #2 why are you using USB 3.0? peripherials only need 2.0. and yes, many above a 2.5" HDD/SSD need external power.. airdeano
M mrapoc New member Dec 4, 2012 #3 Just had one in the shop and thought it may work. So what would I need for my 5.25" bluray drive on usb?
A airdeano New member Dec 4, 2012 #4 usually, there is a second USB cable for the power aspect and one for DATA. the ones i have seen have a dual USB 2.0 plug. since it doesn't have an onboard power adapter. airdeano
Bang New member Dec 5, 2012 #5 I cant see why you would want to use an adaptor rather than its innate transfer method.
A airdeano New member Dec 5, 2012 #6 because some drives need wattage to run and USB can't carry that load, hence external power adapters are needed. and blu-ray drives can fall into that catagory. airdeano
