badatgames18
my gtx2s
my adatas
hypers can work on sb.. just needs the right mobo and some tweaking (ud7/5 B2 and the maximus boards will do the job)
@ rawz.. you need to change ctrl and data voltages to .495-.490 and play with skew voltages on m4e or any of the rog boards..
Hypers still>psc, bbse, bdbg, hynix for benching on sb at least.
So defintely recommend the gene z or m4e (if you benching multi cards).. hope i helped some on your decision
EDIT: btw mnh-e are hard as balls to find (since most of the good ones died) best bet is to find high bin mgh-e.. so far my 2000c7 cmg dommies, adata xpg 2200+, and of course gtx2 work fine on sb.. all are mgh-e
my adatas
