JezEngland
Hi,
TinyTom uses a test bench for the rig in the videos on Youtube.
My current rig is in an ANTEC P183 case, it's used alot for gaming.
I currently run high-end reference NVIDIA cards, they are 480's. They can get noisy and need alot of cooling. Same for all the components need good cooling.
Custom coolers for these high-end cards are lovely, keeping the components alot cooler and running quieter, though they exhaust the heat inside the case, unlike the reference coolers.
I'd like a test bench with the motherboard flat so it can hold the big CPU cooler without me worrying and I'd like a complete copper heatsink, they're very heavy. And 2 custom cooled high-end graphics cards. All the heat will be well dispersed into the open air. The components will be cooler, the rig will be quieter.
I'd need a regular stock of air-in-a-can to keep it clean.
I don't think I'll mod my current rig to be on a bench and am very considerate for the bench idea for the next build
Do you consider doing this idea. Are you using a tower? Have you got a test bench? Are there issues an experienced user can warn?
Advice, suggestions, ideas please.
Thanks
Thanks
