Rob_the_scot
Here I have a matx case just sitting there, the front of the case bezel was destroyed and 2 looked a bit tacky
the structure of the case is well build so I thought hay lets try to mod it.
I removed all the drive bays (does a allow a 3.5 to be bolted at the bottom of the case).
For those wondering the measurements of the front inside of the case are (floor to top fan) is 25cm/250mm..water cooling support????
The front mesh/bolts was just a idea was thinking of a industrial themed pc...go to homebase/bq buy shorter hex bolts ,replace the front panel with some sort of fine mesh, with the hole on top of the case I was thinking of fitting lamptron switches to keep in with the industrial feel.
As for the side panel no idea, but please give your input on any aspect of the case.
As for hardware inside the case I was thinking I5, matx board 3.5 ssd and a 7000 card
*I have no idea why the second pic uploaded like this was taking and uploaded as the same way as the rest.
