looz
Active member
Question, would someone enthusiastic about that brand be called a Nobhead?
Yea. Any studio monitors will destroy gaming branded speakers. And I am constantly trying to make people buy them over regular speakers, but he asked for speakers to be as small as possible. Studio monitors dont fall into that category.
My JBL Control Ones are 22 years old. The first 14 years they were used in a sound control room at work. When this got decommissioned I got to keep 2 pairs of them. They are great rugged little speakers that do indeed go loud. The biggest advantages they have is that they are quite shallow speakers so can easily sit behind monitors and the reflex ports are front facing allowing them to be placed very close to walls without adversely affecting the sound quality. If anything, it helps to reinforce the bass as that's the only area they are really lacking. A 4" woofer in a cabinet that small is never going to produce masses of bass.Yeah, after some more advice I’ve steered away from 2.1 and now just want 2.0 system.
That link of yours, those are very nice, compact and cute looking. Why do I need a small amplifier? Do you have any recommendation for the purpose you mentioned?
They are also listed as ”passive”, what does that mean exactly?...
"Amplified my nob with some Schiit."Nobheads and Schhit Stacks. Gotta love quirky names.
It's probably the worst name ever tbh lol.
Just don't ever put your nob in the schiit. It would be a real bummer.
I would try and avoid all PC speakers if you can. Mostly because even the best become far too expensive.
Get a decent set of monitors, and some stands if you need them. They will last you a lifetime.
https://www.amazon.co.uk/JBL-Contro...rds=jbl+control+powered&qid=1590600634&sr=8-2
An example of. Get a small amplifier you can hide, job done. They have been winning awards for 25 years.
I don't know man. I mean, they look similar. They are active too, which is great. I just have no idea how they sound.
Make sure you at least read some reviews first.
It could be the microphone used or they could be that bad. This is a good video showing proper JBL controls ones. (Not mine, but seems pretty well recorded) He gives them some serious volume abuse towards the end which causes the distortion and the built in limiting filaments to light up inside.
https://www.youtube.com/watch?v=ytmJNgYD5iQ&t=145s
Nice video and seems like a nice couple of compact speakers. Although for me personally, I'm not sure if I'd go for those since they require an AMP.
With that said, I'm currently debating wether or not to keep my newly ordered Creative Soundblaster X3 external soundcard or not (since you can plug speakers in into the back of it and also a headset on the front. Hence switching between them on the unit itself (I believe).
