In a dilemma.
merrymustu
I have a asus p5g41C- MLX mobo with kingston pc3-10700 1333MHz ddr3 ram.
When I look at spd timings in cpu-z, it shows limited timings such as CAS, RAS to CAS, RAS to precharge etc. for different frequencies. But when I turn up in the bios, there are a lot many more options such as tRRD, tRTP, tWTR etc. and I don't know what to set them to for the system to post successfully. So far I have been unable to post with more than 544MHz dram frequency in cpu-z (ie 1088MHz) coz I can't set the timings correctly.
Please Help.
You just need to set the timings 9-9-9-24 or what ever your RAM is and make sure it's running at the specified voltage, it should run at 1333mhz if the timings and voltage are correct.
Also you might have to set the frequency to 1333mhz in the BIOS.
In the bios, the dram timings are given in this order:
tCL
tRP
tRCD
tWR
tRFC
tWTR
tRRD
tRTP
Also here's a screenshot of my cpu-z spd section:
Now can you please tell me what to fill where and what things to keep as they are and not mess with them????
Like this
But in my bios, there's no tRAS as I mentioned before. What is its substitute in the list of options that are available in my bios? (see previous post on list of timing options available) Anyways thanks for your help.
Try tRC.
For your BIOS try
tCL - 9
tRP - 9
tRCD - 9
tRC -24
Or what ever your timings are. Never seen settings like that before tbh but thats my guess.
