Hello
So even though this is still a work in progress I wanted to get some time in on it before I had to take it apart and install the cooling loop.
This Build is In the Build Logs Section under Welcome to The Machine.
It's an ASUS X99 Deluxe/U3.1
Intel 5930K
32 GB Corsair Dominator Platinum 3200Mhz CAS 16
(For the Moment It has a EVGA GTX 590 in it, That changes later today when The GTX 980Ti shows up)
Booting from a Samsung 950 Pro 512 GB NVME Drive.
This thing OC's Like a champ hit 4.5 out of the box at 1.25v The memory however has been giving me issues. No matter what I try It Hangs, gives error codes for modules, sometimes memory, but usually some other module. It seems to hit a wall at just shy of 2400mhz. Like I said in my other thread I'm not fluent in ASUS BIOS terminology, I'm coming up from the X58 Chipset where I could see what the changes were doing on the same page. I am just not sure what I am missing with this.
Maybe I lost at the lottery this time since it is dependent on the CPU.
Rather than trying to explain it all I have a couple of screen shots for you so you can tell me if I've gone looney.
AIDA Report
https://onedrive.live.com/redir?resid=3204011C6ECE0256!18257&authkey=!AOxZQ9xYeckMrOQ&ithint=file%2chtm
CPUZ Screens
Bios Shots
This is the basic Page, note also that the CPU fan isn't showing up. The CPU Speed is shown at stock and the memory is shown at 2400, but XMP profile is enabled.
Advanced Main Page Same thing.
Ai Tweaker Page, Note the XMP Profile is enabled above it but still reports 2400 Mhz.
Not sure if this has anything to do with it DRAM SPD Write ability???
The XMP Timings are in place though.
Thanks to anyone who cares to help on this one.
Intel 5930K
AIDA Report
CPUZ Screens
Bios Shots
