Oh just that? Did I not see somewhere that 2x Xeon 2687's can get these kind of numbers?
I thought I would address that question again as I can provide more detailed information now. I talked to a friend of mine who's using two 2687W CPUs for folding exclusively.
There are new P8104 WUs (to keep it as up to date as possible) out now, which we will compare here:
My system pulls 700W from the wall folding these, and can do about 690k PPD on average if those were the only WU being folded. The two 2687W CPUs can now produces their most ideal score: 430k PPD on average. So my system is basically producing 60% more PPD on average.
But this is a relative number, because the faster a WU gets finished the more bonus points you get. In order to really compare the speed of two systems such as these, you have to compare the time per frame (TPF) values of both systems. These indicate how long it takes for each percentage point of this particular WU to get finished.
The two 2687W CPUs run with 8 minutes and 55 seconds just about 30% slower than my quad 6180 SE setup. My system needs for the same process 6 minutes 25 seconds. So real computing power difference is merely 30%.
However the Intels pull "only" 470W from the socket compared to my 700W. My system pulls nearly 50% more from the wall for 30% more speed, and a 60% increase in PPD.
In the end if you compare these two systems it is really hard to know which is better in terms of PPD/watt. Depending on the WU these numbers can shift one or the other way. But hopefully this will explain why this is one of the best CPU-based Folidng@Home systems you could buy for somewhat normal amounts of money. The two 2687W CPU-setup costs just a little less. So unless you go quad Intel and spend twice the amount of money I put into my rig (if not more), this is pretty much it.
And you can tell by the PPD the system has produced. Over a 28-day period it averaged about 575.000 PPD. A big number
(source for the PPD average:
http://stats.free-dc.org/stats.php?page=user&proj=fah&name=rhodrykorb98860)
