What Nobody Tells You Before Buying a Graphics Card
kartikpal
Raw benchmark numbers lie. Not intentionally, but they do.
Review rigs run top-tier CPUs paired with the latest everything. Your setup doesn't. A card that crushes benchmarks on a review site can bottleneck badly on a system two generations behind. Always check CPU-GPU pairing before spending.
VRAM is the thing buyers consistently underestimate. Games right now push past 8GB at 1440p with textures maxed out. A card with 12GB or 16GB ages far better than a slightly faster one with less memory. That gap widens every single year.
Thermals matter more than spec sheets suggest. Some cards run dangerously hot under sustained load in tight cases. Check the TDP, then confirm your power supply has at least 100W of headroom above the card's rated draw. Skipping this step is a bad idea.
Driver stability on fresh GPU launches is rough. I learned this the frustrating way on a card bought within its first month of release. Checking community forums before buying any new GPU saves real headaches.
And honestly, most people sleep on the used GPU market. Cards from one generation back deliver exceptional value, especially when paired with a solid processor. I've seen builders get 90% of flagship performance at nearly half the cost.
Buy smart. The newest card on the shelf isn't always the best card for your build.
