sfelock
So here's how the story goes:
Today, while doing some light weight gaing, the fan on 1 of my 2 6970 cards ramped up. I have Sapphire TRIXX software installed to help the cards mitigate the higher temps while serious gaming. I thought it sounded as though it ramped up a bit high. So I swiftly exited the game and noticed the fan never ramped down to normal speed. However the second card ramped down just fine. I thought it was a glitch in the system to I rebooted but it immediately ramped up to 100%. I opened my AMD suite and noticed, while it was in fact recognized, it was marked as disabled with no way to enable it. So I took to more intensive measures. I shut down and opened the system up. I swapped cards in the PCIE lanes to see if it was the lane or the card. Upon boot I found the same issue. So I repeated my tests, this time removing one of the cards. Booted with the same result. I then repeated the process only moving the card to my other PCIE lane, same result. One last time I repeated the process, this time switching cards and placing it in the original lane, success, this card didn't ramp up. Just to be sure, I tried it in the other PCIE lane with the same results, iot was in fact the card and not the motherboard. I began searching online for answers but none of them seemed to point to why my card would be ramping up like it is, and why it would be showing as disabled in the software suite. I have checked that my drivers are up to date, as is my software suite. I have tried both the stable version and the beta version, both with the same results.
Now just to clarify, I have also tried using different (and NO) software to control the fan speed within the card, I have pretty much exhausted any means of testing these cards available to me. Also, at no time during this rather odd event did I ever lose graphic display, the card in question was hooked as my primary card that was feeding my displays.
EDIT: Oh yea, the card in question is an XFX Radeon HD 6970, I have just submitted a support ticket with them, as the cards carry a *lifetime* warranty, given that XFX doesn't feel the *life* of my card is over.
		 Reballing most probably!! But yeah might be worth it
