R [R-DEV]UK_Force New member Apr 22, 2007 #1 Is there any way you can change a standard IDE HDD into an external one, or is it only SATA HDD's ?
I ionicle New member Apr 22, 2007 #2 you can, with an external hard drive cage, dunno where to get them from anymore, but it is posible then it will connect to the pc via USB
H Ham New member Apr 22, 2007 #3 Ive got an Akasa Intergral P2 and its fantastic. Does SATA & IDE drives. linky However if you dont need the SATA function, go with an IDE Icy box. As theyre pretty darn cheap now. linky 2
B BloomerzUK New member Apr 22, 2007 #4 KustomPCs have a wide range of External Caddie, super cheap to. http://www.kustompcs.co.uk/acatalog/External_Boxes.html#a3857 I am getting one soon.
R [R-DEV]UK_Force New member Apr 22, 2007 #5 http://www.tekheads.co.uk/s/product?product=606559 Is that it? One of these, and all I do is pop in my IDE HDD and thats it? If so thats fantastic ???
B BloomerzUK New member Apr 22, 2007 #7 name='!TIMMY!' said: Yeah i think that will do Click to expand... Ditto!
