I7 Gaming/video making pc
tuningman
Well basicly after 2 years after i bough some Dual Core i find it time for me to upgrade to a complete new system, this is what I bough
CPU: I7 2600K
Motherboard: Asus P8P67 rev.3
Ram: 2X4GB Corsair Vengeance 1866MHz
CPU-cooler: Prolimatech Megahalems rev.b with 2x Silverstone FN123 fans on it
SSD: Crusial RealSSD C300 60GB
Grafics card: Gigabyte GTX560 Ti SoC 1GB
have a monitor/storage HDD's etc. case= antec 1200
Now my question towards you would be, Is this a decent system to go for?
Also i want to go for Dual monitor at high resolution (1920*1080) will this be a problem for this system. Also i'll be gaming alot and making videos with vegas etc so i'm hoping i won't have any problems with this rig.
Thanks for reading
The bits will work well together and do what you want to do better than you're used to I would think - which is probably the aim of the exercise
To comment further tho, I'd change out your choice of cpu cooler. The Noctua NH-D14 isn't my weapon of choice, but looking at what you're planning to buy and the tremendous job it does, I'd seriously consider getting it instead of the Megahalem+fans. The Noctua will come with fans for around the same ball-park price, but do a much better job I'm sure. I assume it comes with the socket fixings, you'd have to check. If it doesn't, it's highly likely Noctua would send them to you. Check and check.
Any more than that - very much need budget info. My first preference on getting gaming components is to blow your load on the best single gpu card out there, and use cottage cheese for the rest of the parts.
Thing is I already bough it, although it will only be send when the new Asus motherboad will come in the store.
First i'm gone check out the GTX 560, if it doesn't fit me i'd props buy a GTX 580
