I5 750 above 95w in HWmonitor?
Nathlm
Sorry I've never overclocked this far before and wanted to know if this is normal thank you again!
could it cause any long or short term affects?
sorry I had an intel board before and it doesn't have as many options and stuff!
so 4Ghz = 95w, 4.2ghz = 109.3w
also what's the max W for this chip?
as you increase voltages you increase the wattage (this is where the heat comes from) I'd go a google search of ur proc and look at intels data sheet it should say the ranges
It says the max TDP is 95w - should I be concerned about going over this?
