New Default Gameplay Ruleset
Players may now hold jump to continuously jump.
The minimum allowed time between jumps has been increased from 50ms to 100ms.
Players may now hold forward and jump to 'bunny hop', allowing them to slowly gain up to 2x their base movement speed.
When wielding the Gauntlet, ground movement speed is increased 6.25%.
Introduced Loadouts, allowing players to select one Primary Weapon (hmg, rl, lg, rg) and one Secondary Weapon (mg, sg, gl, pg).
Added the command "weapon toggle" to toggle between your Primary and Secondary weapons.
Unified weapon respawn time to 5 seconds across all gamemodes.
Added global Ammo Packs, in lieu of weapon specific ammo, where each pack grants you a small amount of ammo for each weapon in your inventory.
Reduced ammo respawn time from 40 seconds to 10 seconds.
Added in-world item timers for "major" items, including armors, megahealth, power-ups, and medkit. Respawn timers blink once per second, and display one "pie piece" for every 5 seconds that has elapsed.
Items have taller pickup collision boxes, so that players will not miss items as they jump over them.
Power-up spawn indicators now appear when a power-up has spawned in the arena.
Enabled self-kills with an additional 1 second respawn penalty.
Railgun damage 80->90
Rocket splash damage 84->100
Gauntlet damage 50->75
Weapon Changes
Added new weapon, the Heavy Machinegun to act as a viable primary infinite range hitscan weapon with some but minor spread.
Lightning Gun now does 6 damage per cell across all rulesets, or 120 damage per second.
Public FFA Settings
New ruleset in full effect
Public Duel Settings
Public TDM Settings
Friendly-Fire disabled.
Power-up drops enabled.
Fraglimit 150
Timelimit 15
Teamsize 5 (no callvoting teamsize).
Public CA Settings
New ruleset enabled without loadouts (new physics, but 'all' weapons - classic ca + hmg)
Round Limit 7
Public CTF Settings
New ruleset enabled without loadouts (new physics, mg starter, in-world item timers, etc)
Timelimit 15
Public FT Settings
Timelimit 15
Public DOM Settings
Weapons drop for additional weapons.
Self damage enabled.
Timelimit 15
Public AD Settings
Timelimit 15
General Game Changes
Fixed the CHEATS ENABLED notification on the map loading screen from lagging behind its proper state.
Reduced the default amount of player movement bobbing.
Reduced the default amount of damage kick movement.
By default, don't show weapons you don't have in inventory on your weaponbar.
By default, bob major items when simpleitems are enabled.
Prevent broken shader image on crosshair '30', '60', '90', which would equate to crosshair "none" as the cycle repeats.
Bots now randomly select loadouts, when applicable.
Greatly reduced multiple pickups prediction errors.
Removed the option to move to FreeCam while dead in elimination based gametypes.
Create Match Features
Now support custom values of starting ammo in AD, CA, DOM, and RR.
Added optional Double Jump physics player movement mechanic.* (*Not yet actually on Create Match UI.)
Arena Changes
Removed Team Arena Runes from all maps.
