Hyper 212 EVO fan question
Chuckers
Hey there chaps, I'm just about to order a Coolermaster Hyper 212 EVO because it's a great budget cooler by all accounts. I have also just got a 2 pack of Corsair's SP120mm Quiet Edition fans and I'm planning what to do with them.
I need some advice as to the configuration of fans on the EVO. Now, I know that I'm going to replace the original fan with one of the SP120's, however, I plan on adding a second fan on the other side of the cooler. My question is whether or not a static pressure optimised fan is what should be used on the exhaust side of the cooler or should I go with a fan that's more orientated towards high air flow?
If the second SP fan is the right sort of fan for the job then great, if not, I'll grab an AF120 to stick on the other side and put the second SP120 in front of my HDD bay.
Apologies if my question has an obvious answer or is poorly phrased but I just want to be sure I'm not screwing anything up! Thanks for any help in advance :)
I think you would be fine with 2 sp fans on fan speed reducers. the static pressure is just fine for this cooler.
