HWmonitor not detecting 1090t
KING_OF_SAND
So I got my 1090t today and it works great, hit the easiest 4ghz i have ever done. But my HW monitor is not detecting my CPU temps? Why? I am using the latest HWM. If there is no fix can someone recommend a good CPU temp monitoring software?
with my formula board I updated bios and lost alot in HWM changed it back and they returned so maybe check for an update
I think it may be something with my BIOS? I am fully updated on it. I just tried Core Temp and the same thing happened...
I use core temp for fulltime monitoring I love it easy and simple to use and its in the sys tray for easy looking. As well as AB running temps in sys tray cpu cool at 24c and gpu at 39c gotta love it. try back tracking a bios and see if that pops it up
Okay i think i found the problem. My asus BIOS has a button you can press (4) at the beginning called "Core Unlocker" << Doesn't do anything. But when i pressed it my BIOS boot screen says "ALL 6 CORES ARE NOW UNLOCKED!!." So i just reset my BIOS, so no longer unlocked, then i OCed to 4ghz again and now not only are my temps now reading but all my cores are at 4ghz, which is what i want.
WTH is the point of the unlocker?
i have sort of the same issue on real temp. it shows me the core temps. but wont detect what speed my 2500 is running at r anything.
I use HWMonitor, sometimes it says stupid stuff like my fans are spinning at 1m+ RPM, but the temps are realistic I think, and they seem to match with the ASUS AI Suite II temps.
