How to set up a 120.3 rev 2
bennywidag
Got my radiator today (cheers phil, its great) and it comes with 5mm thick foam, in shape of the shroud, and about 6 black screws, a bronze screw and a washer.
i dont know for the life of me what to do with al of these, and would appreciate anyone with expreience helping me out.
£45 and you have a deal
nah, i think the neoprene foam is for making sure all air is coming from the radiator and not the outside, to the fans, and im not sure about the gold screw though
a rev 3 from phil is 55 quid, so for the extra 10 quid i think ill get phils guarantee, 30 quid and you have got a deal...
The 120.3 has a bleed screw so you can bleed the air out of the rad. Thats what the brass one is and the washer - they're just spares.
The neoprene gasket goes between your rad and fans so you have a tight air seal and the 6 screws i suspect are to fix the shroud (if youve got one) to the sides of the rad.
If you need any more help then just PM me.
£55 for a 120.3 is very cheap.
You bought a mach II but wont justify paying £55 for the thing that can cool your cpu/gfx
The mind really does boggle. :confused:
