Save the My documents folder and saved games folder from C:\users\*your username* then overwrite the one from your fresh install. I have done this many times before and had no probs.
Some games save to a folder where the game is installed though so you may need to make a copy of that. If there is one it will say "save game" or something like that.
You need to copy all save games from where they are on your old install and replace them exactly where you got the from on your new install.
Most games save in My Documents in C:\users\*your user name* but some games will save in C:\users\*your user name*\ saved games and others save in a folder where the game is installed.
Wherever the save file for your game is, copy it, and put it exactly where you got it from but on your fresh install, you will have to do it all manually though they won't find their own way.
Just copy the My Documents folder, Saved Games folder, and any save game folders from the games directory from your old install and overwrite the ones on your fresh install.
