How to Get Music from iPod to Computer?
nancynan
Banned
There are many cases that we should get music from computer. While our computer is reset, or the hardware of our computer is broken, we need to backup our favourite music, movies, photos. In that case, we need to get music from ipod to computer. Thus, we need a transfer tooliPod to Computer Transfer to fulfill this requirement to protect our favourite from being destroyed.
For mac,you can login the following site:
http://www.ipod-computer.net/ipod-to-mac-transfer.html
Before you run our program, please be sure you have installed iTunes on your computer, and you can manage your ipod device with no problem.
Step1. After your iPhone/iPod/iTouch connected to pc, Launch the program you will see the right UI. Normally, the program will search the device automatically. If the device is enabled, the files (songs/movies/photos) will be shown in the list.
Step2. Choose the list and files you want to transfer , Click the Export button.
Step3. After you clicking the Export button, the following window will pop up, you can choose transferring to computer or iTunes directly. You can set the output folder at Advanced->Options before transferring.
Step4. When the transferring finished, the following window will pop up. It shows that how many files have been done. You can click the OK button to view the output files.
Also ,if you want to know more about the information,you can visit here
Now you have successfully got music from ipod to computer!
Or just use winamp,1. its free, 2. alot of people already have it and 3. its basicaly just -Find songs you want to copy off > tell it to copy off-
