How memory frequency affects latency - Tighter timings vs. Higher speeds?
nice :)
some excellent info there
wonder if I can get my RAM at PC2-8000 on CAS5? :) am on PC2-6400 CAS4 atm
I got it to DDR-900 on CAS4 before :D
just been looking around and it looks like it's do-able on my RAM :)
might give it a go later :D
was just reading another site that got 1300Mhz out of them :eek:
I got the ram to PC2-8000 speeds with the same voltage :)
(it came up on bootup as PC2-8500 Dual Channel Interleaved tho)
I just can't seem to get it to work at PC2-8000 with the cpu at 3.2ghz :confused: :( works fine at PC2-6400 cas4 tho :rolleyes: :mad:
Think it's something to do with the mobo :(
You can acheive 1000mhz at 2.6ghz but not 1000mhz at 3.2ghz...
Is the ram stable at 2.6 - memtest, orthos ram stress etc?
More juice to the memory controller ftw
I tried putting the mem to 2.2 and 2.25 volts but it didn't make any difference :( but with the cpu at 2.66 it boots up fine PC2-8000 cas5 (2.1v).
Seems a bit strange :(
I only gave it a quick test in super_pi just to see if it booted ok etc.
The only difference is the divider so it should be ok.
It doesn't even POST with the cpu at 3.2ghz tho
