SPS Moderator Jan 6, 2014 #2 On the CPU-Z validation page just copy and paste the text under the Forum/Sign. Banner section (bottom right) into your signature.
Edge New member Jan 6, 2014 #3 Open CPU-Z, click the "Validate" button and use the top "Online Mode" option. Once done, it'll open your own person page at http://valid.canardpc.com/ In the bottom right corner, you will find a forum banner. Then just open up your user control panel, edit signature, and drop it in
M MadShadow New member Jan 6, 2014 #4 So I get this: EDIT: its gone Ignrore the spaces I put in there. (Otherwise it wont display) I put it in the picture and text part of the signature, and neither work. Help! Last edited: Jan 6, 2014
SPS Moderator Jan 6, 2014 #5 Did you tick the publish box? Login to http://valid.canardpc.com/ and see if you can publish it from there or try to re-validate it.
M MadShadow New member Jan 6, 2014 #6 Thank you! I didn't check the "publish" box the first time, but when I did, it worked.
