how bendable is hose?
blair
i have a problem i want to water cool but i need to make a U turn in the space of 10cm with 5/8" OD hose will it kink if i do this?
It may work at start,but as its heating up,it will kink in very short time,did the same,and i have too rebuild with some 45 and 90 degree fittings soon.
Recommend you do it right first time. Rebuilding the wc-loop later,is soo annoying.
i would need 2 on each side in the space for 10cm it isnt gonna fit and it would look really odd i might just get the 120m rad so i can mount internally.
