Homeplugs
Hay11Mac
Hi Guys,
I will be moving rooms soon, and I have no way of getting internet in the room unless I use Homeplugs
The Homeplug will need to be connected to a Netgear Switch (Which I already have)
Can you guys recommend good Homeplugs
Thanks
Hay x
Do you have coaxial cable in your room? I ask because I was in a similar circumstance and found the best solution for me was to use MOCA (Multimedia over Coax Alliance). It can be expensive but the speed is great.
Unfortunately not :(
I have a Devolo (not sure if they are available in the UK) Powerline kit for more than 3 years and it's been really reliable so far. For whatever reason the network transfer speeds are sometimes slower than the internet connection, but I guess that's because of the crappy router.
They are up to 500mb - Mine even list the connection to the router being 1.0gbps - so you should be pretty close to getting those speeds
