His radeon hd 7950 bios help!!!!!
Firstly why do you want to update the bios? You should only EVER update the bios if you are having a problem that it can fix.
Secondly you may be on some sort of odd bios like I was with my 7970. Basically XFX put their own bios on my card and the stock volts were so low I couldn't even get to 1ghz without upping the volts. I tried to put an Asus bios on but the card refused and simply spat it so I was stuck.
As I say unless there's something badly wrong with your card there's no point changing the bios.
