HIS 4870 Iceq4+ Problem
iceie
I was playing Crysis warhead and suddenly my screen turn from colorful to screechy blocks and I have no idea what caused that any idea?
I have a Acer AL1916 monitor
The system setting I set for the game is
Resolution is 1280x1024
Every other setting is at Enthusiast setting
I set the graphic card at 66% fan speed
790 Mhz for the Gpu Clock and 1100 Mhz for the Memory Clock
The software is
Driver Packaging Version 8.65-090813a-087735C-ATI
Catalyst™ Version 09.9
Provider ATI Technologies Inc.
2D Driver Version 6.14.10.6999
2D Driver File Path System/CurrentControlSet/Control/Video/{082DCC0C-1D7C-40E8-9EF5-6E958CCB27DE}/0000
Direct3D Version 6.14.10.0697
OpenGL Version 6.14.10.8918
Catalyst™ Control Center Version 2009.0813.2131.36817
Primary Adapter
Graphics Card Manufacturer Powered by ATI
Graphics Chipset ATI Radeon HD 4800 Series
Device ID 9440
Vendor 1002
Subsystem ID 2007
Subsystem Vendor ID 1787
Graphics Bus Capability PCI Express 2.0
Maximum Bus Setting PCI Express 2.0 x16
BIOS Version 000.000.000.000
BIOS Part Number 113-SBSJ2G09-00R-01
BIOS Date 2009/02/06
Memory Size 1024 MB
Memory Type GDDR5
Core Clock in MHz 770 MHz
Memory Clock in MHz 1000 MHz
Total Memory Bandwidth in GByte/s 128.0 GByte/s
The rest of my system is
Intel core 2 duo E8400 at 3.5 Ghz at 1.2v
CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800
Corsair Tx 650w power supply
Lian li pc-k58
Window xp professional sp 2
Here is the image i posted about the problem
http://i2.sqi.sh/s_1/GG/dsc02043.jpg
http://i2.sqi.sh/s_1/GG/dsc02040.jpg
Thanks For helping me out I really appreciate that
Is it still like it?
if yes:
Does it do it when the system is posting?
Does it do it with windows loaded?
Does it do it in game?
ya it been going like that for a couple of time
The system post fine and the windows loaded fine
It only does it in the game
First thing i would try then is uninstall the drivers. Do a driver clean/sweep and then reinstall the drivers with the lastest.
Make sure you do all those steps before posting back ;)
I did all the steps and i tried the game again and this time it is working fine, turn out it was the driver issue
Thank you tom
;) phew, I was thinking OH NOES RMA RMA RMA, it's all good though, as long as it only does it in games.
