paulstung
:::Your CPU also gets pretty unusually warm for the game you are plying. Tweak your computer's CPU cooler so it spins faster as the temp rises, or get another one that performs well. Keep your computer dust free ( it can cause heat buildup, therefore instability ).::
How would I go about that?Do I go into the Bios?I have just done a restart and had a look and it gives me the option to change the cpu speeds ranging from standard to turbo also manual there is also an option to enable disable,cpu fan monitoring.I,m not that confident for manual so should I just set to turbo?
As for dust it is cleaned weekly,and a new cooler is on the cards as well as some of those new corsair fans,so thats all good on that point just need to wait for Christmas to be over for deliveries to get back to the norm.
