High pitch case fan niose
Mr Muggles
Hi guys
Just put two fans in the roof of my NZXT Hades and when I put the side panel on one of the fans makes this high pitch noise :(
Any ideas? Don't really want to not have the side panel on if at all possible.
I don't know what "pitch" noise means but I guess it's because of negative air-pressure in ur case? (exhaust fans r pulling more air out of the case than the intake fans pushing in the case ...or the opposite)
just guessing
If it only occurs when the side panel is on, I'd guess either the negative pressure, or that the fans are transferring vibrations to case? If so, do you have any rubber fan mounts to hand?
I thought you used roof fans to push the air out so, maybe I should reverse the one next to fan near the cpu cooler.
Don't have any rubber fan mounts james.
