hi there! i very much need some assistance please.
first off im very green and have just built my first custom pc. so as you may guess i have becoome stuck
asus sabertooth x58
intel i7 950
gigabyte gtx 460 ti soc
12gb mushkin blackline
128gb kingston ssd
the problem i have is from the very first moment i pressed the on switch, the led's went round and all seemed good, got into bios fine.
trouble is that the optical drive wont open, the light blinks when i press open so it has power. its name is there in the bios too, it just wont open or spin. and i need this to put windows and drivers on and dont know how to fix it.
i have also tried a different drive which had the same problem, so it cant be a faulty drive.
any help on this would be muchly appreciated
thanks
asus sabertooth x58
intel i7 950
128gb kingston ssd
thanks
