Ok guys (Mav especially:wink: ) got a weird one for you.....
I KNOW my cpu can do 2.6ghz easily as it has done in my system and my friends and it will happily run 2 instances of prime etc BUT i have recently (past 2 months) been getting blue screens.... EVEN AT STOCK SPEEDS FOR EVERYTHING!!!
My spec is below. I tried running the onboard memtest with my ram @ 200mhz (3-4-4-10) and it had errors all over the place. Do you think this is what it would be? Surely ram should pass memtest at it's stock speeds??:?
Is it worth flashing to another bios for greater compatibility? If so which should i go for?:?
Also one last thing... (If all was working well) and i set my cpu multi to 10 and the fsb to 240mhz and drop the htt multiplier to 4x on a 166 divider should everything technically work as if it were it's defaults (except the cpu would be 2400mhz)? Only the motherboard is technically underclocked as it would be a 960mhz fsb instead of 1000. Is that right?:?
THANKS GUYS!!!
THANKS GUYS!!!
