S shazamy13 New member Mar 3, 2009 #1 in short, i broke my 200mm side panel fan on my CM Cosmos S. i want to replace it obviously, anyone know how? and is there any particular fan you would suggest? i prefer silent ones over high air flow ones. Thanks in advance. :worship:
tinytomlogan The Guvnor Staff member Mar 3, 2009 #2 Uncle google says: http://www.google.co.uk/products?hl...a=X&oi=product_result_group&resnum=1&ct=title you probs wont get anything else mate tbh.
S shazamy13 New member Mar 3, 2009 #4 thanks tinytom, but my main question wasn't what to replace it with, rather how to replace it. i can't seem to find out how to get it out. any ideas?
K k4p84 New member Mar 3, 2009 #5 pop off the side panel think there were two screws holding the fan into the dust filter. unscrew those and it just pops out. i never bothered putting the screws back in. it sits securely enough without. if all else fails the whole side can be broken down into it 4 main bits with ease: the metal side panel the metal mesh covering the fan the dust filter than screw onto the metal side panel and holds the metal mesh in place the 20cm fan hope that helps mate ED
S shazamy13 New member Mar 15, 2009 #6 sorry for not checking back, but your method worked. Thanks k4p84 p.s. it has 4 screws not 2, then just yanked it out.
K k4p84 New member Mar 15, 2009 #7 name='shazamy13' said: sorry for not checking back, but your method worked. Thanks k4p84 p.s. it has 4 screws not 2, then just yanked it out. Click to expand... Glad it worked out for you mate ED
DeMoB New member Mar 15, 2009 #8 I had a friend that broke the side fan on his cosmos s, so he got in touch with coolermaster and they sent him out a new one, with a fan guard! So if you haven't bought anything yet, it might be worth getting in touch with CM. Dan
