Okay, I'm thinking of upgrading from my trusty overclocked 2500+ XPM (2400mhz) because video editing, encoding and multi-tasking is chugging a bit.... well.... a lot...
I want to stick with AMD, so I'm looking at the Athlon 64's. I haven't stayed current with the whole hammer series because I stuck with Socket A, so I would really like some advice, and judging from the system specs here, it seems like almost everyone owns either an A64, an Opty or an X2
I'm certainly thinking that a dual core would be the way to go. I tend to have a lot of apps open at the same time, and waiting for things to happen gets me a little up tight !!
If you all agree, then is there a particular core I should be going for ? I plan to overclock a bit, as the CPU will be water cooled, so what is the price/performance sweetspot for X2s ? A 4400+ Toledo core is over £100 more than a 3800+ Manchester core - is that a step really worth taking ? Could I just get the 3800+ and run it a bit faster to get the best whack for my cash ? I'm presuming that I will see a serious improvement on my current setup regardless of which X2 I choose ?
All advice and buying assistance welcomed !!
