Help Project Cougar , Orange??
dracorodrigo
I have this simple case and had already made ​​a very simple case modding it, just paint the cabinet, however, parts bought these days, one of the zotac Gtx 650, and a Dual-x cooler Cougar, both orange, and I want to make another case modding with Orange, what ideals you have for this office?
Why live in Brazil for case modding parts are very expensive and have not had the opportunity to buy them but soon buy: D
I bought the parts have not arrived yet but I want the opnion of you. If you can help .....
Sorry I made this text in Google Translator kk D:
Do not know if you use some sort of 3D program to test various painting styles and etc at the office, but they use, I can not use, and use, which use?
Note: I bought Orange Leds
If your brought orange LED's then you dont want anything else orange IMHO
If you want orange stuff in your case - buy white LED's :)
orange will certainly be the polar opposite of that blue..
Haven't seen a case done that way before.. it's not actually that terrible :P
eu queria era trocar o azul , e remodelar todo o gabinete , por um aspecto mais Cougar , mas não sei o que fazer , se pinto de preto e laranja ou o que faço isso que eu queria a ajuda :D
