jlkf3
Hi All,
I've been having some serious issues installing the Samsung SSD 840 Series 120GB (840 SATA 6GBS 2.5 - Man PT# MZ-7TD120BW) SSD drive into my set-up (found in signature).
SSD F/W Version: DXT07B0Q
The problems i have:
* Unable install Windows 7 x64 on drive (Fails on "expanding windows files 1%")
* Unable to update F/W - I've tried using Samsung Magician 3.2, 4.0 and 4.1 and also created both boot to USB and boot to CD method using version 3.2.
* I've successfully cloned an image to SSD and the OS booted correctly , but its very very slow and i was unable to do anything.
* Enabled TRIM etc... which then eventually stopped me from being able to boot
* I've attempted to run Samsung Performance Benchmark but the disk R/W is so slow I've never let it complete.
* Chipset drivers are up-to-date
* BIOS has been flashed to the most recent image
* Sata is set AHCI
As you can tell I've spent numerous hours attempting to find solutions but sadly got not where. The only thing i can think off is that this drive is either faulty or not compatible with with my set-up.
Anyways...
If you have any ideas then please let me know.
Thank you in advance for your responses.
P.S.
First post
* Sata is set AHCI
Anyways...
P.S.
First post
