Help me make a decision, Which Kit?
gibant1
Hi, My current system runs at 3.84 on Air cooling. What should I do
Buy a watercooling kit, say a Danger den.
Do as above then go for TEC cooling
Buy a Vapochill Standalone XE kit and try to build it in my lian case.
Buy a l nVentiv Mach II ST.
Wait until I have more cash and go for the Vapochill LS
I haven't done any of the above before, so would it be good experience to go through the water/tec route before going Phasechange?
Then there's the cost water £200
With TEC $400
Vapochill kit £430
Nventiv £400
Vapochill £550
And how much more could I get out of my 3.2Ghz P4 northwood with the respective kits
Thank's for any help.
get a mach2 m8, without doubt. tbh there pretty easy 2 set up. alot easier than settin up a pelt system. jus look around the forums, or ask phil (owner of this site) 2 hook u up with sum extreme coolin :cool:
shigs
If you can wait for a few weeks, we will getting in the new Mach II's and GT's, offered with warranty ;) As Warlord has said, these are the best units to get for extreme cooling.
Deffinetly the mach 2, there alot simpler to set up then a propper watercooling tec kit, and as far as i can see easier to maintain over the long run for the same level of oc. But you will still have the grtaphics, chipset, ram all still in need of some cooling, which if you wanted you could then try water tec on there.
The Prommy air cooling solution is good with sinks on the n/s bridge ram etc good large passive ones with quiet fans.
Or for abit more work prommy water will give you a great system and at a quieter ambiant level with possible more oc'ing.
