Help me find a PSU
For the nearly non-existant performance differences between the Titan and the GTX780 save the £300 and use that to get a 256GB SSD instead of the 128GB one and throw in the corsair AX760(i) (I model might come under "too many unwanted features", if so, use the non- i version). Would work out cheaper too and you wouldn't lose any performance. This chance would probably leave you £100 or so under the current spend.
even use the £300 so get a nice monitor(s) for gaming.
I agree with Vortical, the GTX 780 is on Par with the Titan for £300 less, it's a no brainer really, i wouldn't really want to spend £300 more on something that'll give you 2-5fps more difference, it all depends on what you intend of doing. The £300, could get you either two nice 24inch monitors, or even a decent 27inch. This would make your gaming experience better IMHO.
Other than that, you could throw in a bigger SSD and save the money towards another 780 at a later date!
Get a Corsair 760, there renown to be one of the best made PSU out there.
