Hey Guys/Girls.
I'm Looking To Build My First Gaming Rig Soon! I'm Doing As Much Research As I Can On What Parts To Get (That's Good Enough For Me).
I Am Having A Little Trouble Finding A Case, Which I Hope You Can Help Me With.
I'm Looking For A Case That Has Tons Of Filters On It. In Which I Mean. Top, Bottom, Front, Back! Basically All Away Around It With VERY LITTLE Room For Empty Hole Space For Dust To Get In. (As You Can Tell, I Hate Dust On Things). Preferably I Would Like To Be Able To See Whats Going On Inside! Front Mounted Fans Would Be Great. I'm Planning On Having LED Fans On The Front. So Need To See Them.
The Case Also Needs To Be Big Enough To Be Able To Fit A Top Mounted Corsair H100i. Also Enough Space To Possibly Use The Other Water Cooling Method, With The Tubes and Reservoir Tank And All That Good Stuff In The Future.
Must Not Be Crazy Pricey, Due To Budget At The Moment.
Any Help and Advice/Ideas Is Greatly Appreciated!
Thanks Guys. :handshake:
