S stocky New member Feb 4, 2006 #21 Hmmm... interesting. It seems that either the fuse is the wrong type, should it be a 5amp? OR - the compressor is broken somewhere :O My money is on the fuse, I'll go and find out which type it should be...
S stocky New member Feb 4, 2006 #23 I can confirm that it is suppose to be a 240V 5Amp fuse - From the mouth of Fatty himself http://www.extremeprometeia.com/forum/showthread.php?t=3257
T Toxic New member Feb 4, 2006 #24 im in the USA though. does it make a differance betwenn our 110 and 240?
S stocky New member Feb 4, 2006 #25 Ah, Radioshack - of course you are! :$ I think it's atleast a 5Amp you need, maybe a 6.3Amp - but try the 5Amp first - it'll only blow if it's not enough.
T Toxic New member Feb 4, 2006 #26 k, so even though im in the USA it still needs a 5 amp 240 volt fuse? right? Thanks, TOXIC
T Toxic New member Feb 4, 2006 #28 k, OMW to radio shack to pick up a 5 amp, 110 volt fuse. Hope it fixes it.
S stocky New member Feb 4, 2006 #29 Let us know if you get it up and running, it sounds like that is probably the issue here
T Toxic New member Feb 4, 2006 #30 k, thank you all for your time. ill be back in an hour and a half.
T Toxic New member Feb 4, 2006 #31 Its Alive, replacing the fuse worked! Im soooooooo Happy. im overclocking TONIGHT! Thanks All, TOXIC
P phil123 New member Feb 5, 2006 #32 thats lucky mate! Report back to us with the clocks you can get from that 4400x2 as im thinking of getting one myself
