Help? EPSON PRINTER PSU BUSTED
denis6902
Mum psu got busted cause its 110v and my bro plugged it on 220v
Will i be able to get replacement components to fix it on farnell website?
Thats the result of the bust!
i moved back to brazil remember? not cheap here, a new printer is over 500, not kidding!
i think i will be easy to find that fuse, but i dont know specs from other two which got busted
can u use UK power over there
if so ill find out how much it is to ship a printer over there to u if you like.
Lol....Voltage here in Sao Paulo is 220V which means i can use UK power things, but power tools like my dremel for example loose a little of power.
It would be nice to get a printer, but it will be so expensive to ship it, and for sure the stupid federal police will get it to charge me 40% of the product value, thats how bad importantion is here in brazil. And we better not start a conversation about exportation cause the stupid president sells everything for banana price, and the poor amazon lots more then 2 great britan size in forest cutting, its just insane how things work here, well...i better stop my politic ideals, cause if i get involved too much or i might endup dead someday.
Does the PCB have any kind of model number on it? Its probably quite unlikely but you might find some diagrams online.
The circular orange thing is a varistor used for surge protection. The markings on it dont seem to relate to much that I can find, but this is probably close to what you are after: http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=5435091
EDIT:
Found a manufacturer PDF online:
http://209.85.229.132/search?q=cach...pdf&cd=1&hl=en&ct=clnk&gl=uk&client=firefox-a
This is the one you're after. Ignore previous RS link:
http://uk.rs-online.com/web/search/searchBrowseAction.html?method=getProduct&R=5434969
I'm surprized the thing busted, but u can replace the components, farnell should be just as good as rs.
Reason I'm surprized is that the components around those things seem to be rated at 250v, and "sometimes" devices like that with just a class 2 figure 8 plug in are rated 110-220v. There should be a manufacturer label on the printer which has the class 2 symbol (which u can actually see on the pcb), serial number, model number... and voltage rating. Be very surprized it's not 110-220.
what printer you running im going to the tip tomorrow. if i can pick one up for you'll for a couple of quid and pull out the PCB .
mick
mick
thanks may,
its a EPSON STYLUS CX5600
model tag: C331A 120V~ 50-60hz 0.6A
under pcb says:
JIA HE B1(DELTA SYMBOL "triangle") 94V-0
thanks a lot once more! :)
Ill see if they have similar model tomorrow when im there. Shouldn't cost more than 50p if there is.
went down today and sorry to say didn't find any of them down there. there was a lot of le mark's though lol.
do me a favour and take a photo of the whole bord for me and ill have a look though my scrps in the loft and see what i have. Might have some thing to match you never know.
sorry for the delay,
Ill see if its matches any of the boards i have up in the loft for you. Will be a couple of days though i have my hands full atm.
