Hello and help !
zx10rc1
Hi,another noob.
Im trying to overclock my system but cant get passed 2.6 ghz.
Ive tried everything and need help please
OS = Vista 32 bit
Case = Cooler Master Centurion case
PS = Thermaltake Toughpower 650W
CPU = Core 2 Duo costa rica E6600 2.4GHz-4MBcache-socket LGA775
Cpu cooling = OCZ Vendetta CPU Cooler Socket 92mm Fan kit
Temp = Via nvidia monitor = cpu 37c system = 41c (temptaken as i write this with nothing else running)
Mobo = ASUSTeK P5N32-E SLI PLUS
Bios = 1002 (latest)
RAM = 4 X DDR2 Corsair xms2 6400 c5 800mhz
Harddrives = Twin 35gig raptors in raid-o
Graphics = 2 x NVIDIA GeForce 8800 GTS in SLI
Temp = Via nvidia monitor = gpu 64c gpu2 = 72c (temp taken as i write this with nothing running)
Sound = Onboard DirectSound Version 6.0.6000.16386
Screen = SyncMaster 206BW,SyncMaster Magic CX206BW (Digital) 3000 : 1 contrast ratio
Overclocked as follows............
Using Ntune on coarse tune
cpu core= 2610
fsb=1164
mem=873
spp & mcp pci-e = 2850
Temps = cpu - 42c system- 46 hardgaming (using nvidia moitor)
gpu core = 576 to 619 (done manually by keeping the nvidia monitor and keeping the values with a green square (if i increase values higher it turns to red)
gpu mem = 837 to 924
well i just wanted to welcome u to the forums :rolleyes:
so WELCOME my friend :D
as for ur overclocking issue or help well , im sure the guys will help u out :rolleyes:
also im still a noob here :p
:wavey: Hello mate and welcome to OC3D. I've moved your thread to a more appropriate section of the forum, and one where you will receive some help. Your E6600 should be good for 3.0Ghz on almost stock voltage. I'll post back here in a bit with a few things to try.
Thanks everyone.
Ive changed and added a few bits to my orgial post.
OS = Vista 32 bit
Temp = Via nvidia monitor = cpu 37c system = 41c (temp taken as i write this with nothing else running)
Graphics = 2 x NVIDIA BFG-GeForce 8800 GTS in SLI 320Mb
Using Ntune
cpu core= 2619
fsb=1164
mem=873
Temps = cpu = 42c and system = 46 after hardgaming (using nvidia moitor)
gpu core = 576 clock to 619 (done manually by keeping the nvidia monitor and keeping the values with a green square (if i increase values higher it turns to red)
gpu mem = 837 clock 924
3dmarko6 around 12000
Im assuming that my rig is capable of way more considering ive added good cooling etc but i just cant do it ,i have tried and tried.
And i have read a far amount to make sure my questions are not to silly.
I am desperate at the moment and have a few newbee problems.
1 - I assume ntune is not a good idea from things ive read ?
2 - in my bios my fsb is 1066 and mulitplyer of 9 as standard which confuses me.
3 - If i use AI Overclock it wont show the speed in the bios or on the ntune view monitor
4 - My first manual overclock (not using ntune) was 1.45volt to the Vcore and dropped multi to 8 and raised fsb to 1400, I left the ram as linked so i think it decreased to compensate but i dont really kow what im saying here !this crippled the system and i had problems with the bios hanging,i had to f5 restore defaults before the hang but just recovered the system but had to use os to recover because vista would not boot.
5 - when ntune is tuning i get a memory crash blue screen at 297mhz from 267mhz .final tune figure that the program settles at is 289 or something.
6 - i have 4 gig of ram but sys shows only 3 gig but the bios shows 4 gig as available,3dmarko6 shows 3gig but shows all the ram slots as full i.e 4 gig (which has confused me no end)
7 - Ive tried 0805 and now 1002 bios updates and i have checked them but stll have problems.
I hoping someone has a similiar rig and would like to attempt to use there settings so i at least would get some form of success and a base to understand and work from etc
Any advice and guidance would be very very appreciated for what its worth
name='zx10rc1' said:
1 - I assume ntune is not a good idea from things ive read ? Correct. You want to manually set everything in the bios (we'll get to that later)
2 - in my bios my fsb is 1066 and mulitplyer of 9 as standard which confuses me. Your fsb is quad pumped. 1066/4 = 266.5 your actual fsb. Multiply this by your cpu multi (9) and you get... 2.4ghz your cpu's stock speed.
3 - If i use AI Overclock it wont show the speed in the bios or on the ntune view monitor Pass. Well, I beleive this is because it is software overcl
ing and has no effect on the bios, the oc is applied in vista somehow.
4 - My first manual overclock (not using ntune) was 1.45volt to the Vcore and dropped multi to 8 and raised fsb to 1400, I left the ram as linked so i think it decreased to compensate but i dont really kow what im saying here !this crippled the system and i had problems with the bios hanging,i had to f5 restore defaults before the hang but just recovered the system but had to use os to recover because vista would not boot. There is more than just cpu vcore to consider. You have four 1gb sticks of ram which can be a pita to OC, your ram divider needs seting, try 1:1 for now. You were shooting for 2.8, 310(1240)*9 might work better...
5 - when ntune is tuning i get a memory crash blue screen at 297mhz from 267mhz .final tune figure that the program settles at is 289 or something. just bin ntune
6 - i have 4 gig of ram but sys shows only 3 gig but the bios shows 4 gig as available,3dmarko6 shows 3gig but shows all the ram slots as full i.e 4 gig (which has confused me no end) 32bit OS can only address up to 4gb, some is used up in hardware addressing e.g 4gb - 512mb for one gfx card leaves 3.5gb and so on. It is common to see 3-3.2gb on 32bit OS using 4gb. You need 64bit to get the full 4gb.
7 - Ive tried 0805 and now 1002 bios updates and i have checked them but stll have problems.stick with the latest bios for now
I'm at work so can't really spend the time needed on this. I'll get back to you this evening if I have time...
Thanks Mr Smith !
Great help.
I have removed ntune and 1 gig or ram
Also have installed PC probe which keeps giving MB Temp warnings of 47c
I have tried another overclock im hoping to post back the settings in 5 mins from this post.
Fingers crossed ! and many many thanks again !
Hello gain !
Ok,im now gettimg worried in a positive way,hop i dont fry anything.
Have tried the following
Nvidia GPU Ex: Disable
Spread Spectrum Control: Disabled all of them
Execute Disable Bit: Disabled it
Virtualization Technology: Disabled it
Enhanced Intel Speedstep: Disabled it
Enhanced C1 (C1E): Disabled it
AI Tuning =manaul
System clocks = left all as 100 and auto for spp,mcp (not sure what all this is)
FSB Mem clock mode = unlinked (tried linked but sys kept freezing)
FSB Mem ratio = auto
FSB QDR Mhz = 1250
Actual FSB =1250
Mem DDR = 800
Actual Mem DDR = 795.5
VCore = Auto (pcprobe shows 1.41volts)
All other Over voltage settings as auto
Getting 2.81 ! show i now be checking temps ?
Pc probe 2
CPU as i type = 46 to 48c (cpu fan showing 1700 rpm)
MB as i type = 46c (pcprobe 2 shows memory at 1.89volts)
Have not touched any ram latency settings as i dont have a clue.Have done a little reading but ram is beyond my graspe and bottle !
Am i on the right track or am i on the verge of disarster ! ?
No probs
I'm forever linking people to this guide as it outlines the principles of overclocking. You won't have the same bios but the method is the same. Read and understand this and you will make leaps and bounds with your overclocking.
Re. the removal of one ram stick - this is not necessary, it is more of a case that 4 sticks don't OC as well as 2. It won't have a huge impact but you may have to tweak subtimings, again, we'll get to that later.
I suggested a 1:1 ram divider to remove ram as the limiting factor.
Read the article and take some time to think about it, look in your bios and then ask more questions :)
Hello again.
Wasnt sure about 1:1 ration as the ram speed shot from the below current 88 to 1280 (matching the fsb speed) do you think its ok to try that ?
Now running....
FSB QDR Mhz = 1280
Actual FSB =1280
Mem DDR = 800
Actual Mem DDR = 800
Getting 2.88 ! show i now be checking temps ?
Thanks again !
Hi, i tried another one and its holding,im just worried im frying somethinmg ?
FSB QDR Mhz = 1380
Actual FSB =1380
Mem DDR = 800
Getting 3.1 ghz
Pcprobe shows cpu as 44c to 48 c as i type this
Mem is showing 44c
I havnt done any thing with the ram as im unsure what to do,im hoping the FSB mem ration set as auto will take care of it ?
System specs as follows and thanks alot guys
OS = Vista 32 bit
RAM = 3 X DDR2 Corsair xms2 6400 c5 800mhz
overclocked to = 640/1050
Thanks again !
