Heatsink
Innocent159
thinking of heatsinks without fans (note: only case fans will be used)
case: Coolermaster CM 690 II Advanced
mobo: Asus Intel P8z77-v Lx Atx
cpu: Intel Core i5 Quad Core 3570K Ivy Bridge with
thermalright heatsink: HR-02 Macho and ifx10.
would it work? and will it provide sufficient cooling for overcooling?
Can I ask why?
Unless you were aiming for a completely passive system it's just all round better to put fans on.
Get a Noctua D14, run the fans at 5v - it will be completely silent and performance will be far better than any passive system
everyone advice me to get Noctua D14 but it not available in S.A. and i just think it would be silent and if it could be below 50`C on oc it would work for me
50 degrees C is a little ambitious for a passive heatsink with an overclock.
Good coolers these days have silent fans anyway. All the noctuas do - as do the BeQuiet series to just name a couple.
Even something like a Coolermaster 612 with voltage resistors at 5v will perform better than anything passive and still be incredibly quiet.
thinking of this type of build (http://iforce.co.nz/i/beugxemx.50p.png) but can't find a z77 chipset and mosfet heatsink. Any suggestion?
cpu heatsink: HR-02 Macho with IFX-10 Backside CPU
ram: Thermalright HR-07 Duo
gpu: stock fans Evga NVIDIA GeForce GTX670 because i can't find heatsink for the card
It would be far cheaper, easier and more effective to buy a good heatsink and turn the fans down to 5v. Every fan in my system is running at 7v/5v and my temps don't go over 80*C during a 10 run IBT session (3770K at 4.4GHz at 1.144v measured at load).
running benchmarking software tend to "wringe" the CPU in loads you'll prolly
not experience to test to stability. so if under "extreme testing" the temps
encountered are 80°, usually the actual operation in normal situations will be
less and maybe even far less.
airdeano
oh, i feel dumb between yous, any idea what temps i'll reach with my cpu oc to +4.2 and the heatsinks on my ram and cpu (maybe on mosfet and chipset) + fans?
Its all down to voltage. But yeah most of your questions have been to put it nicely - silly.
