Hi guys
Relatively new here and new to building, I would appreciate your help on a build that I am planning. I have listed components and checked prices (mainly on Amazon) and the build comes to around £1,700.
Case: Phanteks Eclipse P400
Mobo: MSI Z370 Gaming Pro Carbon AC ATX
CPU: Intel 8th Gen Core i5-8600K
GFX: MSI NVIDIA 1080 TI Gaming X
Storage: Samsung 250GB EVO NVMe SSD + Samsung EVO 950 1TB SSD
RAM: Corsair Vengeance RGB 16GB (2x8) DDR4 2666MHz
Power: Corsair RM650X
CPU Cooler: Cryorig H7Quad Lumi 120mm Fan
Case cooling: 2x Noctua NF-A14 140mm fan
Case also comes with 2x 120mm fans
My budget is around £1,500 - £1,800. The rig will be used mainly for 2k gaming, namely PUBG, BF1, GTA 5 etc. I don't plan on overclocking as I feel the components are sufficient for what I want to use the rig for as it stands (+ I've never done it before
How would you rate this build? What components would you recommend me to swap out and in? My friend was telling me to switch out the CPU cooler to a Noctua NH D15, but I feared this may not fit into the case as it is such a large cooler... I also didn't find it very aesthetically pleasing...
I also need advice on how to arrange the fans as to maximise the cooling. I was thinking to put 1 140mm fan at the front, another 140mm on the top and 1 120mm at the back. And the spare 120mm maybe stick at the front?
Appreciate any advice!
