Have I set up my water-cooling correctly?
Yeah - I havent' done water-cooling before, so I didnt want to try it on my whole system. (hence only cooling the gpu). THe graphics card is an ati 9800xt (not state of the art, but fine for counter-strike:source, world of warcraft and call of duty 2) - possibly with COD2 on lower detail. I thought I might try and overclock it a bit. The mobo is pc2700 by default, but I have pc3200 RAM (only cost about 10 pounds more - I got 2*1gb sticks) - I thought that would let me overclock the CPU a lot easier, if only by a little bit.
So far, since my last post, it hasn't leaked at all - thats hopeful.
i still dont know if my gpu still works or if I was a bit too thourough when cleaning off the old paste.
Looks good, what kit you got there?
Oh and seing as you bought a rad/res/pump, its worth buying a cpu block aswell! Helps it seem better value :p
Just done rebuilding my loop actually... took some pictures but i've gone and changed graphics card...
Oh and regarding leakage, loops don't leak on their own, only when somebody sets them up wrong! By the way regarding the PTFE comment over there. Its simple: If it has a ruber 'o-ring', it doesn't need PTFE, if it hasn't got an 'o-ring', it does!
