Should i put my 2x200mm fans that are on top of the case to blow cold air in or blowing hot out. Will it disturbe the CPU cooler fans if there is air coming in the middle of the cooler?
^^^^ What he said. With a full tower case you are best having front to back/roof airflow. Sometimes sff cases are better having all the case fans blowing in provided you have enough ventilation for the air to escape.
