Ralm
Hi there,
After a while of being bored of my CoolerMaster HAF-X case, I wanted to change it for 2 reasons:
1 - Make it mine and not just another HAF-X.
2 - Give it more contrast, since all black is just too dumb.
So I started thinking on whites and blue stuff, I wanted to keep a bit of the black but not all. I saw some videos of a guy that painted his HAF-X although I didnt like the way he did it 100%.
Then I saw this:
and I though to my self: This looks awesome, this is it.
So yeah, Im paiting it exactly like that for now.
Although I already painted the side panels, I dont like that much the end result because I never painted anything with spray. Basically I did a couple mistakes making the final result not as good as I wanted. I didnt took pictures of it and I wont for now. I might show the end project, the case.
Anyway, today I started with the top plastic part. I'm afraid about it because its plastic. I hope that the paint just doesnt gets off in the end.
Here some pics:
Starting point with it dirty.
Part clean with Benzina.
1st Layer of Primer.
Ok then, so if you have some tips let me know.
I painted that with a paint brush.
My final layers are gona be with spray and Im gona use mtn Hardcore 2 cans and I will give it 3 layers of that, plus 2 layers of enamel paint.
Hope you guys like it,
Ralms
Then I saw this:
Here some pics:
Ralms
