I have had the same delema and I thought 600T white cause I just really like the look of it, hate the red fans on hafx and too lazy to want to change em, now if they came out stock with blue fans i'd really be in trouble deciding but there's just something about that white case dont ya think?
Raven RV-02, I know it wasn't one of the choices but that case is awesome. I bought the HAF-X and although I think it is a great case my friend got the RV-02 and that case is just insane for air cooling and style.
600T just because I think the HAF is ugly and common but the other cases mentioned are better imo also don't forget about the RV03.
Yerr the HAF X is abit ugly, but which case would you recommend the RV-02 or the RV-03.
Unless you need the space for your kit, skip the HAF X and I'll probably pick the mid-towers mentioned above. The 600T has Corsair's eye for detail with fit and finish, and sensible features and design. Silverstone's RV-02E and RV-03 are quite different beast from each other, I'm still personally leaning towards the RV-02E even if it's design makes it silly long, so keep that in mind if you have limited desktop space.
For aircooling,no doubt.Silverstone raven RV02.Watercooling with a 360 rad CM haf932 advanced.
HAF-X supports a wider range of form factors IIRC
I kind of guessed that due to the sure size of it but i was more worried about the RV-02E and the 600T.
The only thing about the silverstone cases that I personally don't like is the 90 degree twist to the motherboard the idea of having all my cables sticking out the top of my machine instead of out the back just don't do it for me.They may perform better but that would look to untidy whereas the 600T everything is out the back all nice and loveley and it is still a really good performing case for an air case. And if you aren't going to water cool its really worth considering. The NH-D14 fits nicely.![]()
