WalkerThePirate
I recently got my HAF X case to store all my goodies. HAF stands for high air flow, but is it really as high as it could be? I didn't think it was, seeing only one front intake fan. That one fan does give high air flow, but if you have a ton of hard drives behind it, the air won't be as effective as it could be. I decided I would try to lower my temps even more by adding on a 120mm Cooler Master R4. To start off, here are my specs:
i7 950 @ 4.2Ghz OC
Asus Sabertooth X58
Corsair Dominator 6GB @ 1600Mhz
EVGA 570 Superclocked
Corsair HX850W
Noctua NH-D14
Before the fan was installed, my idle CPU temps were at 37-39° C on average.
My idle VGA temps were at 34-38° C on average, but did not change after installation.
First, I took off all of the metal tabs in front of the optical drive bays. Then, I removed all of the front grills and both hot swap bays.
Then I ziptied the four corners of the fans to 2 of the front grills.
After that, I unscrewed the PCB and moved it up. Since there are two hot swap bays, I put it directly under the top plastic grill, leaving room for an optical drive (I don't have one at the moment. Also, dirty side window, deal with it
Lastly, I snapped in the two attached grills and then the middle grill.
I now have a nice cool flow of air going directly to my RAM and HSF.
Now, you might be wondering. Is it worth the trouble? Well, I'll let the temperatures do the talking. You decide.
EDIT: I forgot to mention, there is no rattling, shaking, or any sort of movement with a tight ziptie. No additional noise was heard, other than the smooth spinning of the fan.
i7 950 @ 4.2Ghz OC
Asus Sabertooth X58
Corsair HX850W
Noctua NH-D14
