H80 fan control problem
VanquishUK
Hello guys i got my H80 today and its all set up i have one problem tho the fan controller does not seem to work i am only using 1 fan on it at the moment due to my case but i will be running 2 soon and the fan thats is on it is a noctua fan.
Any ideas i tried a thing where you reset it but did nothing.
Just got a H80 unit today and had the same problem.
-4 pin molex connected to PSU
-fans connected to fan controller on H80 unit
-3 pin connected to "CPU_FAN" header on the mobo
I tested the CPU_FAN header with another fan and it works. I also used the paper clip test on another PSU with the H80 and the pump kicks on but again no fans or lights.
Just RMA the thing
I had an issue with my H100.
I plugged the CPU fan (on the molex power cable) into the CPU_FAN header and all the other fans into my fan controller. When i booted i got a fan warning and temps started rising.
I then plugged all my fans into the motherboard fan headers and when i booted it all worked. After that i plugged all the case fans and radiator fans back into the fan controller, leaving the CPU fan in the CPU_FAN header, and when i rebooted it all worked fine.
