Hello all. I wanted to get some feedback on my fan setup or if i should change the fans. Ive heard about static pressure for the h100 but not sure if it would be worth it or not. Below is how i have my fans setup, hopefully i explained it so you can follow. thanks a bunch
Case - CM Storm Trooper
CPU - i7 3770k (not overclock)
Heatsink - Corsair H100
EVGA GTX 680 Signature 2
the fan setup i have is 5 Cooler Master Excaliber fans
http://www.coolermaster-usa.com/product.php?product_id=2965&product_name=Excalibur (R4-EXBB-20PK-R0)
I have two of these on my h100 Pulling air from the outside into the case (so cool air over the grill of my h100)
I have 1 blowing air over my HDD's which is not blowing the air into the case. i have the HDD bay turned so it sucks air in from the side case and blows it out the other side of the case
I have 1 of these fans pulling air in from the front of the case and blowing it through the case past the GPU.
I have 1 of these on the back of the case Pulling the air out of the case.
